cava_11
Dec 07, 2020Initiate
GS305E poe
Hi everyone and thank you in advance for your support,
I wanted to know if it is possible to power the gs305e via poe.
I have a GS728TPv2 to which the gs305e would be connected via a cat 6 cable, the lan cable lenght is about 20mt.
If the gs305e is not suitable which 5 port managed switch could be used?
Thank you
Alberto
PoE powered switches are a rare species.
GS108Tv3 https://www.netgear.com/business/wired/switches/smart-managed-pro-cloud/gs108tv3
GS105PE https://www.netgear.com/business/wired/switches/smart-managed-plus/gs105pe
- cava_11Initiate
Thank you so much for your support, very apreciated and helpfull
