barreaudb
Apr 04, 2025Aspirant
GS305E Trunking tagged and untagged vlans
Hi there. I recently purchased a GS308EPP. In basic 802.1Q mode, I temporarily used it to connect: - (V)lan 1 (default Lan): still a few controlling/managing devices; - Vlan 20 : Data; and - Vla...
fzmuhammad
Apr 05, 2025Guide
It sounds like the GS305E isn’t handling VLANs the same way as the GS308EPP, which is causing your inter-VLAN communication issues. While both support 802.1Q VLAN tagging, the GS305E has limited VLAN management features compared to the GS308EPP. This is likely why:
IoT devices can access the internet but can’t reach the Data VLAN.
Inter-VLAN routing or proper VLAN isolation is not behaving as expected.
The GS305E might not be properly tagging/untagging VLANs or forwarding traffic across VLANs like the GS308EPP does.
Even with firewall rules in place, if the switch doesn’t handle VLAN tagging correctly, traffic won’t route as intended. You may need to either go back to the GS308EPP or use a more advanced switch that properly supports VLAN trunking and inter-VLAN communication for your setup.
- barreaudbApr 05, 2025Aspirant
Hi fzmuhammad and thanks! that's my fear tbh, but I think I have missed a setup parameter and perhaps someone will catch it here.
- schumakuApr 05, 2025Guru - Experienced User
barreaudb two things I don't understand:
- You talk of a firewall and an AP, but only one port seems to be configured as a correct trunk config - for your use case, I tend to suspect at least two ports with proper trunks.
- What is the idea of overloading the config with more than one VLAN ID as tagged? This is a guarantee for a nightmare. Sure, on a few switch platforms, the so called Asymmetric Switching was sometimes possible (with an additional control, as the switch must support that) - but most decent switches don't support this feature anymore. What does partially work in your case (on both switches when I get you right) is some kind of that.
Since no Netgear Plus Switches (new naming Easy Smart Managed Essential Switches) are supporting IPv4 "routing" - and I doubt you are keen to deal with complex ACL to create some firewall functionality - better handle the IP routing and firewall handling on some more sophisticated firewall system with some fancy customer friendlier controls.
Keep us posted how this works out.
-Kurt.
Hi Kurt, wow thanks so much for looking at this.
To give more background:
- AP is not at issue here. It's currently powered directly and wired by ethernet to my firewall. It will be powered by the Gs308epp once I have ensured Gs305e to properly work.
- You're right: plan is to have Gs308epp with 3 proper trunks: firewall, AP and wired switchs (perhaps Gs305e's) in 2 other locations. In the future, a camera will be added to Gs308epp.
- Unsure I get the question right on overloading config with more than one Vlan. Do you mean on the switch ? I simply tried to duplicate something that has been working on the Gs308epp as I find Gs305e manual a bit less clear that the latter one
- Just to try to move on, am I correct in understanding yello strips in picture mean that setting has to be duplicated ?
Thanks again schumaku 🙌
