DREato
Aug 29, 2024Follower
GS305EP -is what I want to do possible?
I have a GS305EP (default config, trunk port 5) with 2 Yaeling POE phones attached (ports 1 and 4). VLAN 50 is set at the phones, and these packets are passed through, unchanged, to the router where ...
schumaku
Sep 01, 2024Guru - Experienced User
Yes, definitively possible. Not different than on most other switches supporting VLANs with simple VLAN config logic. Just double and tripple check you have removed the default [U]tagged setting on the ports used as access ports.
Reminder: These Plus switches Web UI (and the legacy Netgear Switch Discovery Protocol used by some of the legcy utilities) can work only on untagged frames, hence the tiny uC does not understand tags.
