DREato
Aug 29, 2024Follower
GS305EP -is what I want to do possible?
I have a GS305EP (default config, trunk port 5) with 2 Yaeling POE phones attached (ports 1 and 4). VLAN 50 is set at the phones, and these packets are passed through, unchanged, to the router where ...
ErwinL
Sep 05, 2024NETGEAR Moderator
Hello DREato
And welcome to the NETGEAR Community! 🙂
Yes it should be possible. If I may ask, do you experience the same when cameras are not connected to the switch? If issue is present when camera is connected, you may also want to check if IGMP snooping is enabled and may also consider enabling IGMP snooping for VLAN on pages 62-64 from the link below. Try also managing the broadcast filerting from pages 25-26 from the same link below. But a packet capture through mirroring the trunk port may surely help.
https://www.downloads.netgear.com/files/GDC/GS305EP/GS305EP-EPP_GS308EP-EPP_UM_EN.pdf
Have a lovely day,
Erwin
Netgear Team
