friendlyguy
Aug 16, 2022Follower
GS305EPP Management VLAN
Hi there! I am trying to configure the GS305EPP in a way that i can integrate it into my management vlan. (this is where the switch should send its DHCPREQUESTS to.) Lets define 3 theoretical VLANs...
schumaku
Aug 16, 2022Guru - Experienced User
There is no management VLAN on most Smart Managed Plus switches (GSxxxE). The tiny management microcontroller for the switch config does work and listen on all VLANs so restricting to just one VLAN isn't possible unfortunately.
