friendlyguy
Aug 16, 2022Follower
GS305EPP Management VLAN
Hi there! I am trying to configure the GS305EPP in a way that i can integrate it into my management vlan. (this is where the switch should send its DHCPREQUESTS to.) Lets define 3 theoretical VLANs...
Retired_Member
Aug 16, 2022Since the native VLAN on your CISCO switch is VLAN 4, this is the VLAN you should use as untagged with its VID (4) as PVID on all links between the switches. It should work. If it doesn't, consider using the 'General' switchport mode on the CISCO switch.
