POEsystem1246
Nov 16, 2023Aspirant
GS305P bocks connection to Internet
Unable to connect through this unmanaged switch. Direct to Comcast modem is ok. The switch is used for a 4 camera surveillance system on Windows 10.
schumaku
Nov 16, 2023Guru - Experienced User
Just a little bit confusing. Four cameras and a PC and a Comcast Modem - with just five ports?
Does this Comcast modem also serve act as a router, serving the LAN for DHCP, assigning private IP addresses to the cameras and the PC?
POEsystem1246
“Does this Comcast modem also serve act as a router, serving the LAN for DHCP, assigning private IP addresses to the cameras and the PC?“
Yes. The modem does everything but I believe I need to do some stuff in the PC surveillance app and Windows.
