Figurz99
Oct 07, 2024Follower
GS305Pv2 PoE compatibility with Ubiqiti Aircube AC
I am not getting any PoE to the Aircube. Aircube works fine on its power adapter. Are they incompatible?
BrianL
Oct 11, 2024NETGEAR Moderator
Hi Figurz99,
Welcome to the community!
I am not certain about this information but it seems that Aircube only supports 24V DC POE passthrough from a POE source which won't be possible with your existing NETGEAR GS305Pv2 switch that only supports:
4 POE/POE+ ports
Up to 30W power per port
Total POE budget of 63W
Kind regards,
BrianL
- schumakuOct 13, 2024Guru - Experienced User
Almost correct BrianL
While most Netgear PoE devices are supporting only true industry standard compliant IEEE 802.3af, 802.3af, or 802.3bt, Ubiquity used to implement the lower-cost passive 24 V, which is proprietary.
Power method 24V DC, 0.83A PoE 24V In on Ethernet port 1
PoE Out Controllable 24V PoE Out (4, 5+, 7, 8-) on WAN Port
Ways off from -any- IEEE industry standards, and not comptible with the GS305Pv2. Not everything claiming to be "PoE" is -really- IEEE compliant PoE.
