xxavarlonxx
Jan 08, 2023Aspirant
GS308E - Cannot open Admin GUI after a few hours
Hi, i have strange problem. I'm using 2 GS308E in my Home network. Both gets a static IP by my DHCP Server. After i boot up the switches everything works fine and i can open den Admin GUI when i type...
schumaku
Jan 08, 2023Guru - Experienced User
The NSDT (Netgear Switch Discovery Tool) is still able to find the switch on the LAN?
Current firmware in place on the GS308E, as of writing v1.0.11?
xxavarlonxx
Jan 19, 2023Aspirant
So yes i had upgraded my switch to thet latest firmware version 1.0.0.11 and I used NSDT. NSDT cannot find my switch. Either when the web gui is reachable or the webgui is not reachable. I put my laptop also in the same network segment ( Im using multiple vlans at home), but also no results with NSDT.
So the problem still exists
