dhcp
Jan 15, 2021Follower
gs308e 5268ac pi-hole
I have att uverse pace 5268AC gateway, netgear gs308e switch, and raspberry pi running pi-hole. I want to connect a single rj45 cable from the 5268AC to the netgear gs308e, and then connect rj45 from gs308e to my computer, and connect rj45 from gs308e to my raspberry pi running pi-hole. If possible, I would still like to use the 5268AC for wireless network connectivity. What settings would I have to use on the gs308e to do this?
Thanks.
1 Reply
dhcp wrote:What settings would I have to use on the gs308e to do this?
None - permitting the gateway is in router mode (as it is because there is wireless et all working). With all Ethernet links up (LED link indications correct), there is nothing that should stop you.
Pi-hole and related settings are your business.
