Sciao
Feb 04, 2022Follower
GS308E becomes unreachable
Hello, i have a strange problem. I have a couple of GS308E manaed switch in my home, i configured both of them with VLAN (802.1Q) since i have a separate vlan for iot/smart devices and everything wo...
SBMeijer
Feb 06, 2022Aspirant
I am running into the same issue. I have 2 of these switches with multiple VLANS.
Here is some ping-output (both of them are acting the same):
Reply from 172.16.99.55: bytes=32 time=11ms TTL=126
Reply from 172.16.99.55: bytes=32 time=7ms TTL=126
Request timed out.
Reply from 172.16.99.55: bytes=32 time=5ms TTL=126
Reply from 172.16.99.55: bytes=32 time=13ms TTL=126
Reply from 172.16.99.55: bytes=32 time=14ms TTL=126
Request timed out.
Reply from 172.16.99.55: bytes=32 time=4ms TTL=126
Reply from 172.16.99.55: bytes=32 time=6ms TTL=126
Request timed out.
Request timed out.
Reply from 172.16.99.55: bytes=32 time=9ms TTL=126
Reply from 172.16.99.55: bytes=32 time=8ms TTL=126
The IP-address is static on boh of the switches.
I tried multiple versions and none are working correctly. Also, the ping is quite stable until i try to login into the GUI.
I have one multicast VLAN and a lot of traffic over them. Would it be possible they are being overloaded?
Bergro
May 22, 2022Aspirant
I have also the ping problem.
I discovered it is caused by my camera software on the PC
If I close the software, then al works fine.
