jreg2k
May 25, 2023Aspirant
GS308E didn't send any data
I am struggling to update my GS308E switch. Every time I try to save a change. I've got this page: xxx.xxx.xxx.xxx didn't send any data I have tried to update the firmware but nothi...
jreg2k
May 26, 2023Aspirant
Hi schumaku,
I used to use Google Chrome and communication errors occurred with this browser. Using Firefox I was able to change settings without any problems.
The only remaining problem concerns updates, which I still can't do, at least I think so, as I can't see the current firmware version that's running at the moment.
Regards.
schumaku
May 26, 2023Guru - Experienced User
Provide a screenshot from the device Web UI entry/home page - titled System Info please.
Considering the html code, the css and the JS is extremely basic: What Chrome browser version are you using, on what platform? Any Internet Security wonders intercepting valid content probably? Have a mobile phone with an average Web browser at hand, connecting to the WiFi network, accessing the same LAN IP of the switch?
- jreg2kMay 26, 2023Aspirant
As requested the System Info screenshot:
Version 113.0.5672.92 (Official Build) (64-bit)
on what platform?
On Fedora Linux with kernel 6.2.15-300.fc38.x86_64
Probably no
Same result with an Android phone .. I was trying to change the hostname, after hiting "Apply", the same screen appears ...
- schumakuJul 23, 2023Guru - Experienced User
Start with updating the switch to the current firmware https://www.netgear.com/support/product/gs308e#download
