mhubel's avatar
mhubel
Tutor
Sep 12, 2023
GS308E for guest VLAN
I am trying to setup a VLAN so that the access point (TP-LINK TL-WA801ND) can have an isolated guest SSID. This is the first time dong this so I am not absolutely sure what should happen but the AP i...
  • mhubel's avatar
    mhubel
    Sep 13, 2023
    Thank you for the reply.
    I believe the problem has been solved although I don't know if the changes made to the switch really made a difference. On the switch, only the uplink and access point connected ports were set to "T" for tags 10 and 20. All ports were left at "U" for tag 1. Then on the router, the interface network port was changed to "VLAN 10" and "VLAN 20". This apparently corrected some instructions posted on YouTube which were  used to initially program the router.
ProSupport for Business
