DJDJDJDJ
Jul 22, 2020Aspirant
How do I configure VLAN with Netgear GS308E and Edge RouterX
Hello,
I am trying to figure out how to configure VLANs on Netgear GS308E to work with Ubiquity Edge Router X. My current setup (as in the diagram) has two access points. AP1 is connected directly to the router and issues correct IP addresses for VLAN 1 (LAN) and VLAN 10 (Guest network). However, AP2 is connected via the Netgear switch. Through this AP, I can get IP address for VLAN 1 only. Guest connections are not issued any IP addresses.
I know that I need to configure VLANs on the Netgear switch. However, I can't seems to find any clear instructions on how to do that for this switch. Web GUI seems to show 4 different things you can configure under the VLAN menu.
Thank you for any help or pointers you can offer.
For complex 802.1q VLANs configs use VLAN -> 802.1Q -> Advanced only.
Add VLAN 10, 20, and 30 to the VLAN config.
For the uplink port and the AP port, add VLAN 10, 20, and 30 as [T]agged.
