DJDJDJDJ
Jul 22, 2020Aspirant
How do I configure VLAN with Netgear GS308E and Edge RouterX
Hello, I am trying to figure out how to configure VLANs on Netgear GS308E to work with Ubiquity Edge Router X. My current setup (as in the diagram) has two access points. AP1 is connected directl...
- Jul 22, 2020
For complex 802.1q VLANs configs use VLAN -> 802.1Q -> Advanced only.
Add VLAN 10, 20, and 30 to the VLAN config.
For the uplink port and the AP port, add VLAN 10, 20, and 30 as [T]agged.
DJDJDJDJ
Additional Images
DJDJDJDJ
Additional Images
- schumakuJul 22, 2020Guru - Experienced User
- DJDJDJDJJul 22, 2020Aspirant
schumaku wrote:For complex 802.1q VLANs configs use VLAN -> 802.1Q -> Advanced only.
Thank you schumaku . Do I need to configure anything in the "Port PVID" section?
There is an untagged VLAN ID 1, so PVID must be set to 1, too - otherwise your primary network (also the management network of the other vendor devices) will no longer work.
