sachinchain80
Oct 21, 2022Aspirant
GS308EPP daisy chain
Hi All I have a GS348 (48port), i will add a GS324 (24port) and presume they should daisy ok? I will need an 8 Port POE switch as well-would the GS308EPP daisy ok or another netgear 8 port sw...
schumaku
Oct 21, 2022Guru - Experienced User
Yes, of course. Depends what you expect performance-wise through the complete daisy-chain however.
sachinchain80
Oct 22, 2022Aspirant
Thank you
Basic small business, only running low perfm PC and a couple of POE access points
