Bryan42
May 29, 2026Aspirant
GS308EPP Plug
Where can I buy a replacement plug? Mine snapped in half and I cannot find any 6.5*3.0 with a 9.5mm barrel length.
If your able to cut off the broke plug and repair it with a new one, then give those a try. NE has a good return policy if those don't work.
Input that model # on Amazon comes up with many different options to try.
- Bryan42Aspirant
No, sorry, I meant literally a replacement barrel plug, not the entire power transformer.
This is the closest I've found, but it's not 9.5mm long so I'm not sure it will work.
Barrel length does not really matter, that just optical.... More useful might be a plug with a grooved head part, avoiding an unexpected disconnection when moving or rearrange cables in the area.
