Bryan42
May 29, 2026Aspirant
GS308EPP Plug
Where can I buy a replacement plug? Mine snapped in half and I cannot find any 6.5*3.0 with a 9.5mm barrel length.
- May 30, 2026
If your able to cut off the broke plug and repair it with a new one, then give those a try. NE has a good return policy if those don't work.
schumaku
May 31, 2026Guru - Experienced User
Barrel length does not really matter, that just optical.... More useful might be a plug with a grooved head part, avoiding an unexpected disconnection when moving or rearrange cables in the area.
