dmacp's avatar
dmacp
GS308EPP power plug
What is the size of the power plug for a GS308EPP PoE switch?
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi dmacp,
    Welcome to the Community!
    If in case you will be needing a replacement, don't hesitate to contact support to get one.
    Kind regards,
    BrianL
  • Hi BrianL​
    Can NETGEAR support supply a 12V DC to 54V DC power supply?  (I need to operate the device from a 12V DC system and I want to avoid the efficiency penalty of double converting).  If not, can you provide the size of the power connector so that I can source a suitable boost converter for this purpose?
    Thanks
    EPICasey
    • schumaku's avatar
      schumaku
      Extreme unlikely.
      Netgear does offer power supplies with the ubiquitous 100...120V AC 60​ Hz and 220...240V AC @50Hz only.
      Compare these dimensions with your switch and the existing power supply for the PoE models operating at 54V DC:
      Outside diameter 6.5mm
      Inside diameter 3mm
      Barrel length 9.5mm.
ProSupport for Business
