Bryan42's avatar
Bryan42
GS308EPP Plug
Where can I buy a replacement plug? Mine snapped in half and I cannot find any 6.5*3.0 with a 9.5mm barrel length.
  • FURRYe38's avatar
    If your able to cut off the broke plug and repair it with a new one, then give those a try. NE has a good return policy if those don't work.
ProSupport for Business
