Bryan42
May 29, 2026Aspirant
GS308EPP Plug
Where can I buy a replacement plug? Mine snapped in half and I cannot find any 6.5*3.0 with a 9.5mm barrel length.
- May 30, 2026
If your able to cut off the broke plug and repair it with a new one, then give those a try. NE has a good return policy if those don't work.
May 29, 2026Guru - Experienced User
Input that model # on Amazon comes up with many different options to try.
- Bryan42May 30, 2026Aspirant
No, sorry, I meant literally a replacement barrel plug, not the entire power transformer.
This is the closest I've found, but it's not 9.5mm long so I'm not sure it will work.
