nikolasgr
Feb 03, 2022Follower
gs308epp vs gs310tp Which one is better?
Hello can you please help me decipher which one is best? Data Sheet GS350series_DS.pdf https://www.downloads.netgear.com/files/GDC/GS305EP/GS305EP_GS305EPP_GS308EP_GS308EPP_GS316E_GS316EPP_D...
Iphie_C
Feb 03, 2022NETGEAR Expert
Hi nikolasgr
It depends on your application.
Hardware:
GS308EPP has 8 PoE+ ports with total 123W PoE budget, no SFP ports for uplink.
GS310TP has 8 PoE+ ports with total 55W PoE budget, and 2 SFP uplink ports.
Software:
GS308EPP is a Plus switch, which has VLAN, QoS, IEEE Energy Efficient Ethernet, Port Mirroring, and advanced PoE controls including PoE scheduling and per port PoE control, etc.
GS310TP is a Smart switch, which has all the Plus switch features + ACL, advanced VLAN, IGMP snooping, STP, SNMP, etc.
You can refer to GS310TP datasheet here:
