Juslisnen
Jan 27, 2021Aspirant
GS308T- No mounting points?
Hi!
I have only ever used unmanaged switches in the past. Appreciate this is only 8 port but it falls into the category of business devices. However I don’t appear to have any mount slots on the underside of the casing to hook onto wall. Is there additional hardware (bracket) that I can purchase for this?
Shame as I was hoping to replace GS108, which has same dimensions (with holes 80mm apart) with this unit.
Thanks in advance
Thanks in advance
Only the 24- and 48-port variants of the S350 Smart Managed Pro Switch Series GS308T, GS310TP, GS324T, GS324TP and GS348T Data Sheet are rack-mountable, indeed.
- JuslisnenAspirantThanks, but due to the size I wasn’t intending to rack Mount it. That would look slightly silly.
I was just hoping the same design applied to the unmanaged switch which is of the same size. So I could hook it onto the wall screws.
Oh well. Never mind eh?
