nismo9132_net's avatar
Dec 27, 2020
GS308T Management VLAN?
Does the GS308T support the specification of a Management VLAN? I have a couple GS308E and a GS305E and they don't support Management VLANs in the web interface, so I'm looking to upgrade to something that supports that since I don't want my switches to have their management interfaces accessible on a network that's more easily accessible.
If it doesn't support Management VLANs, then are there other switches that support it that are reasonably priced with 5/8 ports?
Thanks!
    Yes, all Smart Managed Pro including those supporting cloud management allow a true management VLAN config.
  • schumaku's avatar
    schumaku
    • nismo9132_net's avatar
      nismo9132_net
      Initiate
      Thanks! That's good to know. I thought that might be the case, but it seemed like only a few on Netgear's site actually had "Configurable Management VLAN" specified as a feature so I thought maybe it was only included on certain models. Sounds like I'll be swapping these GS305E/GS308E switches out for Smart Managed Pro switches soon. Thanks again and happy holidays!
ProSupport for Business
