nismo9132_net
Dec 27, 2020Initiate
GS308T Management VLAN?
Does the GS308T support the specification of a Management VLAN? I have a couple GS308E and a GS305E and they don't support Management VLANs in the web interface, so I'm looking to upgrade to somethin...
- Dec 28, 2020
nismo9132_net wrote:Does the GS308T support the specification of a Management VLAN?
Yes, all Smart Managed Pro including those supporting cloud management allow a true management VLAN config.
schumaku
Dec 28, 2020Guru - Experienced User
- nismo9132_netDec 28, 2020Initiate
Thanks! That's good to know. I thought that might be the case, but it seemed like only a few on Netgear's site actually had "Configurable Management VLAN" specified as a feature so I thought maybe it was only included on certain models. Sounds like I'll be swapping these GS305E/GS308E switches out for Smart Managed Pro switches soon. Thanks again and happy holidays!
