jukste
Jul 05, 2023Aspirant
GS308T Issue to create VLAN via GUI
I am sure I miss something but I am not even able to simply create / declare a VLAN. Here are my steps also illustrated with an image : 1) I enable VLAN Assignment Mode in Security - Port Authen...
- Jul 15, 2023
Ok so, what is a workaround for that is using a numerical keypad.
The field VLAN ID does not accept other input, I tested on another machine with external keyboard and there the numerical keypad is recognized but using regular numerical keys does not work either.
Thanks a lot for your guidance schumaku, much appreciated !
schumaku
Jul 05, 2023Guru - Experienced User
Sorry for my confusion, it should not make any difference on the GS308T, both VLAN and name should be add-able, in both Basic and Advanced view:
jukste
Jul 06, 2023Aspirant
Thanks a lot for the attempt !
I tried to play with the views as well but still the VLAN ID field does not accept any input, I still think I miss the way to enable the creation of VLAN somehow but it is not to be found in user manual.
I will continue to investigate.
