jukste
Jul 05, 2023Aspirant
GS308T Issue to create VLAN via GUI
I am sure I miss something but I am not even able to simply create / declare a VLAN. Here are my steps also illustrated with an image : 1) I enable VLAN Assignment Mode in Security - Port Authen...
- Jul 15, 2023
Ok so, what is a workaround for that is using a numerical keypad.
The field VLAN ID does not accept other input, I tested on another machine with external keyboard and there the numerical keypad is recognized but using regular numerical keys does not work either.
Thanks a lot for your guidance schumaku, much appreciated !
schumaku
Jul 12, 2023Guru - Experienced User
(ignore - 1.0.5.7 is in place)
jukste
Jul 15, 2023Aspirant
- schumakuJul 16, 2023Guru - Experienced User
This reads to me like an oddity on this popular operating system, much less an issue on the simple Web implementation. I'm more than happy you have resolved the issue!
