Kadaj29
Oct 25, 2024Aspirant
GS308T issue
Hi all, I have a GS308T connected with 2 nases and other stuff. What is odd is that every time my router (fritzbox 6690) restarts, the port forwarding does not work anymore and I'm forced to re...
Kadaj29
Oct 30, 2024Aspirant
schumaku Thanks for your input.
I did write to AVM, just waiting for a reply. I totally get your point, but i don't understand why this is happening: router up and running, all good, all port forwarding working. Router restarts, port forwarding on all devices connected to the switch blocked. Restarting switch, all good again.
In the logs of the switch there is nothing, no traps nor blocking rule.
I don't get it!
I just factory reset the switch, reconfigured from a backup, same story. Could it be a upnp issue? Because the ports i opened manually are getting through, the ones with upnp not.
