bonnedav
Jun 28, 2019Aspirant
GS308T Remote Diagnostics
What does the Remote Diagnostics feature of the GS308T switch do and how do I use it?
- Jun 28, 2019
I figgured it out. It enables a telnet cli on port 60000. Just login with username:admin password:(your web management password). Note however that sense cli is a defineing feature of fully managed switches, this feature on plus/pro switches is intended for diagnostics and tech support use only. (At leest that is what any Netgear employe will tell you.)
schumaku
Jun 28, 2019Guru - Experienced User
It's intended for Netgear support and engineering troubleshooting on demand only.
Technically it's kind of a shell access.
