PhilJW
Jun 26, 2021Aspirant
GS308T wall mount option
Hi all
Ive just bought a GS308T which I was hoping to wall mount.
However its doesnt appear to have the 'T' shaped holes for the screw heads and the label on the underside looks a lot bigger - ie it covers where the T holes should be - than on the GS308
Am I missing something?
If not is there a wall mounting kit I could buy - or is it inadvisible to wall mount it?
Many thanks
1 Reply
