MirceaDamian
Feb 11, 2021Aspirant
GS310TP - Autonegotiation on g8 to 100FD with a 1000FD capable cable and device
Hi, To my shame (after probably 4 months operating like that) I have noticed that a port (g8) is negotiating 100FD towards a device which happens to be the Router of my home WiFi mesh system (ano...
- Feb 13, 2021
Ok, so just to conclude on this topic for anyone who might read it latter.
I did a software upgrade to 1.0.1.2 and tried again with my MacBook and the 10GbE adapter and now I'm getting consistently 1000FD.
My guess is that something got in a strange state and the upgrade fixed that. I have tried to plug/un-plug the cable multiple times and everytime it worked as expected (auto negotiation at 1000FD).
MirceaDamian
Just to rule that out I have just done a test with a 3m patchcord connected to my 10GbE USB-C transciever to a MacBook pro.
I've got 1000FD on all ports of the switch except g8 which reliably stays at 100FD.
So I'm leaning towards a small hardware issue idea as well.
I will do the software upgrade as well just to be sure and if things look the same I will probably ask for RMA.
MirceaDamian
Feb 13, 2021Aspirant
