tylerm
Nov 28, 2022Initiate
Management VLAN on GS310TP
I'm struggling to use the management VLAN ID under IP Address Configuration and have read through every post related to VLANs and PVID that I can find. Here's what I have:
VLANS (setup on both switches):
- VLAN ID 1 - default/workstation VLAN (192.168.1.x)
- VLAN ID 8 - management VLAN (192.168.8.x)
Switch A, a ubiquiti unifi switch, where:
- Port 2, which is connected to Switch B is setup with:
- Untagged: 1
- PVID: 1 (I don't actually see a setting for this, so assuming this)
Switch B, a Netgear GS310TP, where:
- Port 7, which is connected to Switch A is setup with:
- Untagged: 1
- PVID: 1
- IP Address Configuration:
- 192.168.8.10
- Management VLAN ID: 8
My firewall is setup to allow traffic across the two VLANs.
As soon as I put in the IP address configuration above on switch B, I cannot access its management interface from anywhere (either from a device on VLAN 1 or VLAN 8). This results in me having to factory reset and start over.
I think I must be missing something. Thanks for taking a look!
Tyler
Oh dear, it looks like its working for me. I re-did the configuration for the 4th time as I was writing up my original post above. I'm not sure what I did differently, but it is now working and accessible on the management VLAN. I'm all good!
1 Reply
- tylermInitiate
