KarMannJRO
Feb 24, 2021Aspirant
GS310TP PoE seems administratively disabled, with no way to re-enable
After I'd been happily running this switch with a Cisco WAP plugged into it for PoE, I saw there was a firmware upgrade available, so I went to check it out. (Yes, this may have been my mistake.) Up...
KarMannJRO
Feb 25, 2021Aspirant
I've realised that I do have one other PD, a TP-Link WA901ND. Having plugged it in, it also isn't powering up at all, but, I'm not sure whether it has a configuration setting that would need to be enabled for it to act as a PD, so that's inconclusive. I haven't used it in years, which is both why it didn't come to mind right away when wanting a PD, and why I'm not sure whether it needs enabling.
- DaneAMar 01, 2021NETGEAR Employee Retired
Let us try this. Kindly upgrade the firmware of your GS310TP to the latest version which is v1.0.2.2. You can download it here. Then, observe if the same problem will occur.
Note that you can perform a factory reset on your GS310TP after doing the firmware upgrade in order to start clean using the latest firmware. Then, reconfigure the settings from scratch. Observe if the same problem will occur.
DaneA
NETGEAR Community Team
