GBale
Jul 19, 2022Aspirant
GS316EP VLAN Configuration
I'm looking at purchasing a GS316EP. Please could somebody confirm if it is possible to configure certain ports to be only able to send & receive to certain other, which can in turn send & receiv...
- Jul 21, 2022
Many thanks for the response.
I had a look at the 'Advanced Port-Based VLAN' in the mannual as you suggested and it appears the solution to my setup is pretty straight forward.
I guess you just need to know where to look!
Thanks again,
Gareth
DaneA
Jul 20, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
You can achieve your goal by implementing Advanced Port-Based VLAN on the GS316EP. With Advanced Port-Based VLAN, one port can be a member of multiple VLANs.
To learn more, kindly read pages 39-42 of the GS316EP user manual here about Advanced Port-Based VLAN.
DaneA
NETGEAR Community Team
GBale
Jul 21, 2022Aspirant
Thanks again,
Gareth
