Issen
Mar 02, 2016Tutor
VLAN Configuration
Hi,
I have installed a new network in our office to start implementing VLANs.
We have today 3 Switches (2x GS724T connected to VMware ESXi Hosts) and (1x GS748T connected to all Laptops and our firewall).
We are using Watchguard XTM 330 as a firewall that support VLAN.
If I use the default settings on does Switches, everything works fine and everyone can ping eachother and all ports using Untagged VLAN 1.
But as soon I start involving VLAN, then do we have some issues.
What I try to do is create a Untagged VLAN for all my laptops.
My Production VLAN are at the moment using VLAN 1 but want to change in the future to VLAN 99.
My Clients will I move to VLAN 97.
When I setup VLAN 97 in my Gateway I can ping it from VLAN 1. But as soon I setup VLAN 97 on my Switches on port 47 and Tagged VLAN 97 on port 48 I can't ping the gateway anymore when I connect my laptop to port 47. (I using Static IP GW: 10.0.97.1 Laptop: 10.0.97.2).
Any ideas how to continue?
Fireware level: 6.3.1.11 on all switches.
Thanks
Christian
Hi Issen,
Welcome to the community! :)
Based from the firmware version 6.3.1.11 you have mentioned, it seems that you have GS748Tv5 and GS724Tv4 switches. Kindly answer the questions below:
a. How is everything connected? Kindly post an image or screenshot of your detailed network setup.
b. Is the port connecting the GS748T to the firewall set to tagged with a PVID=1 and member of all VLANs?
You may check this link as reference guide.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Issen,
DaneA
- IssenTutor
Hi Dane,
Thanks for the welcome.
Yes the models is GS748Tv5 and GS724Tv4.
I have try to attach a small visio picture as an overview.
But where Port 27 is my "Guest Network Port" are using Untagged VLAN 97 and on port 40, 49 and 50 I used Tagged.
Also on port 27 have I used PVID 97 to really say it should be on that VLAN.
Port 40 goes to my Watchguard XTM Firewall/Router where I also have VLAN 97 configured as Tagged VLAN.
And to verify that VLAN doesn't work on the NetGear did I configured one interface on my GS724Tv4 with VLAN97 and static IP on both my laptop and the server. And I can't ping between them.
I will look at your link tomorrow.
Thanks
Christian
Hi Issen,
Just kindly check the link and that might help.
Also, is VLAN routing configured on the GS748Tv5? What I think is the ping reaches the gateway, have you tried to configure a default route?
DaneA
