Issen
Mar 02, 2016Tutor
VLAN Configuration
Hi, I have installed a new network in our office to start implementing VLANs. We have today 3 Switches (2x GS724T connected to VMware ESXi Hosts) and (1x GS748T connected to all Laptops and our...
- Mar 02, 2016
Hi Issen,
Welcome to the community! :)
Based from the firmware version 6.3.1.11 you have mentioned, it seems that you have GS748Tv5 and GS724Tv4 switches. Kindly answer the questions below:
a. How is everything connected? Kindly post an image or screenshot of your detailed network setup.
b. Is the port connecting the GS748T to the firewall set to tagged with a PVID=1 and member of all VLANs?
You may check this link as reference guide.
DaneA
NETGEAR Community Team
DaneA
Mar 02, 2016NETGEAR Employee Retired
Hi Issen,
DaneA
- IssenMar 02, 2016Tutor
Hi Dane,
Thanks for the welcome.
Yes the models is GS748Tv5 and GS724Tv4.
I have try to attach a small visio picture as an overview.
But where Port 27 is my "Guest Network Port" are using Untagged VLAN 97 and on port 40, 49 and 50 I used Tagged.
Also on port 27 have I used PVID 97 to really say it should be on that VLAN.
Port 40 goes to my Watchguard XTM Firewall/Router where I also have VLAN 97 configured as Tagged VLAN.
And to verify that VLAN doesn't work on the NetGear did I configured one interface on my GS724Tv4 with VLAN97 and static IP on both my laptop and the server. And I can't ping between them.
I will look at your link tomorrow.
Thanks
Christian
- DaneAMar 02, 2016NETGEAR Employee Retired
Hi Issen,
Just kindly check the link and that might help.
Also, is VLAN routing configured on the GS748Tv5? What I think is the ping reaches the gateway, have you tried to configure a default route?
DaneA
- IssenMar 03, 2016Tutor
Hi Dane,
I follow the link you sent me but that didn't work.
I have also add the Route in my IP settings but it doesn't work, and I have try to ping in the same VLAN without jumping to the Watchguard.
It seams like VLAN between Switch and Switch doesn't work.
Any more test I can try? Or should I open a Support ticket?
/Christian
