pnarayanswamy
Oct 10, 2022Aspirant
GS316EPP not linking up at 1Gig
Hi Folks I recently purchased Netgear GS316EPP and I am connecting it to a Netgear ProSafe 8 Port Gigabit switch and the links is not negotiating to 1G. it always remains at 100Mbps. Is this a bu...
- Oct 10, 2022
make sure to use high quality cat 5e cables or cat 6 cables. I've seen sketchy cat 5e cables not connect at gigabit rates.
Oct 10, 2022Guru - Experienced User
- pnarayanswamyOct 10, 2022Aspirant
I agree with you. It seems that the cable I am using though shows all pins connected 1-8, and looks perfect but the cable definitely is bad. First look I thought the crimping was bad and re-crimped to get the same pathetic problem. Replaced the cable with another and I see Gig speed. I unfortunately have to rewire my whole home!!! Sad but have to redo!!!
I used cable from Amazon - FastCat Cat6 and I encourage folks not to buy this cable. Reviews in Amazon was great but I and one more who has given a review (which I missed) are victims of this shady cable. Requested Amazon for a refund but Amazon being Amazon directed me to Vendor saying please contact vendor, as return date expired!!. God knows where they source these cables and what they will do. Amazon must do some stringent quality checks!!!!
- plemansOct 11, 2022Guru - Experienced User
Really check your ends carefully. I've seen the wires nicked when stripping off the outer cover for making ends and that cause cables to still pass a continuity tester but fail actual usage. (made this mistake myself a time or 2).
It sucks because your tester will say everything is fine because its just testing that the copper is intact. Its just once you start putting data down it that there's issues.
