Harmansend
Feb 11, 2022Aspirant
GS316EPP VLAN Configuration
I just bought a GS316EPP switch to replace an IntelliNet switch which worked well, except that the fan goes bad after 1 year, and after having one replaced under warranty I've given up with it. I...
Feb 12, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with LAN Switch (FS,GS and M Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/bd-p/business-smart-plus-click-switches
Thank you.
