davidcrowder
Aug 25, 2021Aspirant
GS324T Port Separation
We have a SG324T that we plan to use as an edge switch. Internet traffic hits it, and then our firewalls plug into it. I would like to designate ports 1-10 to be isolated and only be able to com...
- Aug 26, 2021
For port 1..12 (VLAN 100 untagged) the PVID must be configured to 100, for port 13...22 (VLAN 101 untagged) the PVID must be configured to 101. Reason: The PVID does define the VLAN where incoming untagged frames are assigned to. That's why you have no communication on the ports you have tested.
davidcrowder
Aug 26, 2021Aspirant
Kurt,
I believe I have tried as you suggest. However, I'm not having any lucking making that work; if I plug a device into port 1 and another into port 2, they do not communicate.
Below are screenshots of the relevant settings. Can you point out where I have gone awry?
Thank you!
schumaku
Aug 26, 2021Guru - Experienced User
- davidcrowderAug 27, 2021Aspirant
That did it. Thank you very much!
