Indusauto
Jul 20, 2021Aspirant
GS324T VPN
Hi, I have purchased a Netgear GS324T switch for my small business and I have a problem. I have connected everything but the VPN network of an external company software does not link to the switch. ...
Indusauto
Well, it is software that works on several computers in the company and the server is located in another city, it is like a personal internal network just to run that program, the fact is that with the old switch it works and I have it now ... but I connect everything to this new switch and the program does not work, the led light of the switch blinks as if trying to connect but does not stay fixed.
schumaku
Jul 20, 2021Guru - Experienced User
Complete unrelated to the VPN in this case.
Still very vague what LED you are referring to. In case this is (or are) the port LEDS, for whatver reason, the links don't come up. Typical cause is almost alwways in tve wiring. Xould ve a switch hardware error, too
Get in touch with the Netgear support and request a replacement. They will guide you over some more tests.
