Game0n
May 27, 2024Aspirant
GS324TP- Speeds are bad when plugged into switch. Help?
The model is GS324TP The switch isn't pulling the proper download speeds. I have tested the speeds from my router with the same cable (so router cat5 cable into laptop) and get great speeds the m...
Game0n
May 28, 2024Aspirant
Thanks for the reply. Honestly, I looked to see if there was an update but I am not sure to tell what version of firmware its on/where to find that info.
The cable isn't the issue I tried that an the switch it was coming from is also a 1gb switch. It has been in place like this for years so for it to have a drastic change in speeds was alarming.
Hitron modem. Model CGNM.
Generally I have my Hitron modem in bridge mode, connected to my PF Sense box, connected to the Netgear GS324TP. Then the GS324TP connects to netgeargs380pp. Diagram below to help.
Yes the picture shows APs but I have unplugged those as well as turned off the PF Sense box so that way I know its literally just the modem and switch working together.
I have been consistently troubleshooting and am at the point where I turned off the PF Sense box and took the modem out of bridge mode so I could test further with the speeds and make sure it wasn't an issue w/my PF Sense box. Yesterday, I tested and found the speeds automatically slow down when I plug in to the GS324TP Switch. I physically took the network cable that is from the GS308PP in the Level2 and plugged it into my laptop in the basement and th speeds were fine, then when i plugged that same network cable into the GS324TP switch the speeds automatically dropped to 8down, and 5 up (it should be at least 92down and 5up).
This equipment has been in place for a while so for it to automatically slow the speeds down I am not sure why that is happening.
If there is no firmware update (not sure how to tell), then I will backup the config and reset it to factory default but I really dont want to do that.
schumaku
May 29, 2024Guru - Experienced User
Start from here: https://www.netgear.com/support/
- Game0nMay 29, 2024Aspirant
Thanks for the reply. I dont' know now if its that switch, I posted a handful of new info in a previous reply/post (don't want to post the same info again here and clutter the thread, please see info in the above reply).
- schumakuMay 29, 2024Guru - Experienced User
Unless I'm wrong, Netgate does have the Ethernet Flow Control enabled by default on the pfSense - so good advise might be to enable Ethernet Flow Control on all switch ports (by default it's disabled because it can lead to bad results, and unmanaged switches default to the same).
