sdct989's avatar
sdct989
Tutor
Mar 21, 2022
GS324TP 1.0.0.38 Firmware Spins Up Fan Frequently
I'm not sure if anyone else has noticed this or not, but with firmware 1.0.0.38 my GS324TP switch seems to spin up the fan for about 15 - 30 seconds every 5 minutes. I've monitored the heat of the un...
  • sdct989's avatar
    Mar 21, 2022
    So after I posted this, I decided to do some more investigation with the firmware. It turns out, that this is the result of heat build up, it's just that the heat build up happens on such an obscure interval that I became convinced that it was some sort of timer.
    When I measured it, the fan turns on whenever my MAC temp sensor gets to a temperature of 51C and then it stays on until the temperature goes down to 45C. For my unit, this happens every 5 minutes on the dot.
    It turns out, that my unit normally sits at 53C when it runs under 1.0.0.30 which it still labels as normal, but this triggers the fan as of 1.0.0.34 which appears to be related to the bug in the release notes for that release https://kb.netgear.com/000062955/GS324T-GS324TP-Firmware-Version-1-0-0-34:
    • Modifies fan behavior so that the fan now activates at low speed at a lower temperature threshold.
    Anyway, not sure if that's really that bad, but I guess there's no bug here, its just that the threshold changed for most likely good reasons.
    I'll try to find some alternative cooling solutions that aren't quite as loud as the internal fans on the device.
ProSupport for Business
