stevieflower
Feb 05, 2020Tutor
Nighthawk R7000 needs frequent reboots
My Nighthawk R7000 -AC1900 router needs to be frequently rebooted. This just started about 2 weeks ago. It was working perfectly. We bought it less than 6 months ago. It might connect to the interet for a few days and then all the sudden stop. I have COX internet and have a ARRIS Surfboard modem and have a MAC. As far as I know nothing has changed in these 2 weeks to cause the need for frequent rebooting. I
I am wondering if there was a firmware update in the last 2 weeks that started this problem. Is there a way to see a log of when my firmware was last updated. I have also read about the Tomato Firmware.
Does anyone have any advice on what steps I should take to figure out this problem?
Thanks!
Running: V1.0.11.116_10.2.100
First, Sorry that this got to long. Please feel free to ignore and not read the whole thing.
I just wanted to relay my experience and how I have the router behaving very well now.
________________________________________________________________________
So I have been plagued with this stupid problem to the point of where I started to look for a different router.
But I'm holding off because I seem to have the router cooperating a lot more by doing a couple of things every day or two, that seem to keep it operating just fine now.
I haven't HAD TO reboot it in a couple of weeks or so! THAT'S PROGRESS!
So first, let me say, I think that ONE of the major problems with this router and its firmware versions, is that it does not handle massive traffic very well, EVEN THOUGHT IT'S A 'GAMING" router.
For my gaming server (which I no longer run or bother with), I had a bunch of ports forwarded to my server's static IP.
Being that these particular ports are well known for the environment I was running, there were constant attacks by :Russia
China
and a few other countries where reporting bad actors was useless.
At one point, so that I wouldn't have to totally remove all the redirects, I just put in a fake IP that went no where on my network, so that any attacks to any of those port ranges would just go to that fake IP.
I also set up huge ranges to redirect attacks to there as well...
THAT WAS A MISTAKE!!!! That's because the router would STILL try to process the requests rather than just ignoring them.
I would notice my entire network starting to grind to a halt , so I'd check the logs and see hundreds of attacks, trying to get into my server. From Remote Desktop attempts to DoS attacks to port hammering, etc.
I'd have to reboot my router and the modem that connects me to my ISP.
Doing so would get me a new external IP as well as clear the cache in the router.
I would also clear the logs, apply and refresh to clean that up.
Sometimes, I couldn't even log into the router and I would have to power cycle it.
I still have some ports open for my security cameras so that I can access away from home.
But with that, I still had the router choke up every couple of days.
I finally decided to REMOVE ALL PORT FORWARDING except for my cameras. Those are vital.
Well that settled things down A LOT!
However, then I would see those same countries trying to access my cameras.
So for those, I tightened up their passwords. At least it won't be easy for those BOZOS to monitor my cams.
But still, the router was not stable. Sure, it was a lot more stable, but I still had to reboot every few days!
To troubleshoot this problem, I have a Command Prompt constantly pinning google.com -t.
When the router would start to get wonky, I'd see packets dropping from the ping.... INTERESTING.
Sure enough, in the logs, I would see attacks, including still, DoS attacks.
But something still didn't seem right.
So then, I added another command prompt window and constantly piinged the router's internal IP.
I wanted to see if pinging outside my network to the internet would fail, but internal pinging was ok.
Sometimes, this was the case ,but other times, more often, when one would start dropping packets, so would the other! HMMMMM
So then, I powered up my laboratory computer, which sits right beside the router and is wired directly into it. This computer does NOT go through anything else, no switches, nothing.
I also ran a command prompt, pinging the router as well.
Now, with 3 pings being monitored, I could get a better visual on where the breakdown is happening.
So now here is where I found what is in fact one of the biggest problems with this dammed router.
THE LOGS! Yes! THE FREAK'N LOGS!
What I discovered that as the log file increased in size, is when the router would start to get wonky!
I could see dropped packets on the external ping, then drops on this machine that pings the router (but it goes through switches). But sometimes, the Lab computer wasn't seeing drops!
But then, I'd start seeing drops on the connected Lab computer.
I started monitoring the logs closer but nothing unexpected was seen.
I did notice, however, that the drops were right around the time that the attackers were trying to get connected to the ports that I did have open.
But at other times, even with that, there was no issues.
I got into the habit of clearing the logs so I would get a clear picture each time.
It's then that I noticed, when I cleared the logs, within seconds, the dropping of packets stopped and the router settled back down!
I've seen this kind of file corruption in older software, but I would have thought that in 2020/2021 there would be much better routines to keep caching in check.
So, very long story short,- remove any port forwarding that you do not NEED
- do not set up huge ranges of ports to forward to a fake IP (if you don't forward ports, the router will just ignore requests to ports not listed)
- clear the log daily (at least to confirm if this solves the problem).
Which version of the firmware are you on?
Which modem model is it?
You put that you need to reboot it but not specifically why. Just that the internet isn't working. Is it connected to wifi but giving you "internet not available" or what exactly is happening?
We just need to figure out if it truly is a router issue or a modem issue.
I've had an arris modem or 2 that would get hot and need the modem and router rebooted to function. Once we isolate the problem, then we can work on steps to fix it.
Here are the extra details I left out in my last message
The firmware I am using is V1.0.9.88_10.2.88
I am needing to reboot because I am loosing my WIFI signal. It usually starts out with my phone or computer asking me to enter to enter my wifi password and then it tells me it is wrong. Or it might ask me to select the wifi and both of my signals appear on the list of available wifis (2.4Ghz and the 5Ghz) but then it won't connect. I have been able to reconnect once I reboot the router, so I am pretty sure it isn't the modem. I did once try to only reboot the modem and that did not work I had to reboot the router.
The modem is Arris Surfboard Model - SB6183
Hopefully, I got everything answered now.
Sadly, I'd start with the firmware. If you search the forums, the R7000 has had quite a few firmware issues. Even worse on the .88 version because of the rollout of Armor.
I'd try downgrading the firmware to the .42 version over a hardwired connection, factory resetting the R7000, and then doing a manual setup (not from a backup configuration).
This tends to have the best results with the R7000.
- ilovepoodlesAspirant
I have this same issue. It appears it's connected on the Netgear site, but my mac says can't connect to the page. I have a Arries Surfboard 8200. It will connect for a while and then just drop off. HELP.
- DDozier110AspirantThe way I solved my issue with the need for daily reboots was too upgrade to the latest firmware version.
- Bikerbill7InitiateMy AC1900 needed reboots multiple times each day. And, as previously mentioned, I had to go to netgear.com to find the latest firmware (1.0.11.123.10.2.100 hot fix). But, I also found an old ticket I submitted in 04/2019 where I was told to change my 2.4 channel to 11 and my 5 channel to 161. Lastly, connect to WAN with cable and change WAN Setup MTU Size to 1450.
(I always run wireless, but changed this also.) So far, for the last 12 hours, I’m still up and running!
- fmalloyLuminary
For what it's worth, V1.0.11.100_10.2.100 was released in April. For some reason, the router doesn't detect it when you check for an update on the router (it says no new updates), but if you navigate to the Support page, you can manually download it and update it from the downloaded file.
I've just updated about an hour ago. We'll see if it's any good...
Hi
And did this update solved the update issue ?
Thanks
Marcel Nijskens
R7000
Windows 10
firmware V1.0.9.88_10.2.88
Hmm
tried reverting to the .42 firm ware but then my speed dramaticly slows from 250 Mb to 90Mb,,,
pff time for another router of maybe wifi access points
- KAPREAspirant
I also had this problem wherein I would get the small explamation point beside my wifi icon on my phone. It was really such an issue as I could not even connect to the network to remotely reset the router. I had to walk over to a different room and restart manually. I tried getting a cooling fan, which did not work. I tried changing to a different outlet thinking it was a power issue. We had to restart the router almost every 3 hours since we kept on getting disconnected. I tried updating my Firmware manually (since for some reason it doesn't show that there's an update on the admin interface) to 11.104-hotfix, but this didn't help either.
I can confirm that rolling back the Firmware to 1.09.42 has fixed the problem and I have not encountered any issues after doing this.
This router is a solid router. I have had it for almost 6 years, but the new Firmware updates just nuked its performance. Better to stick with something that works. The old firmware works fine. I just stick the router in a shelf and forget.Thank you for the suggestion. This really was a great solution.
I have a newer router also and this just started happening a few days ago. I have to reboot my router every morning now. I have read all the posts here and maybe give the suggestions a try... or just wait until they release a new version that may fix it.
- onimic70Guide
Roll back the firmware to this version - V1.0.9.42_10.2.44
Once I did that I haven't had an issue. Sucks as there are probably security holes as this is an older firmware.
Here's what I that fixed my issue.
1.) Downloaded the firmware and had it saved on my desktop so I did the firmware push via a network cable vs. wireless.
2.) Factory reset the router to wipe all settings out.
3.) Once logged into the newly reset router, did the manual firmware update that I downloaded above.
4.) Router rebooted.
5.) Setup my wifi network and anything else( I have a NAS and some remote stuff that I had to redo) and then went and added all my devices to the WIFI and all has been good since. (Did this over the summer so its been over 6 months solid).
Good luck and Netgear sucks for not doing something better to resolve this issue...
- Jms2829AspirantHow do you download old firmware?
- DrWobieInitiate
Same modem, same router, same problem. Have had to restart my router several times today.
When I do not have Internet access, restarting the modem does not help, but restarting the router does.
Looking for a solution. (Wasted all day on this!)
today same issue again .. Maybe this will help https://twitter.com/mnijskens/status/1359209920290242560
what should be a better option Buy TPlink mesh set !!
Get rid of the #!$@@% Netgear router. They probrably do that on purpose so you have to buy new stuff !!
- MrMezAspirant
I know it's a n old thread, but I have tried everything. Turned out to be a faulty network cable
i'm using a brandnew CAT5 cable !
It used to work perfect and it didn't after firmware updates ... tried a lot of version .. it is costing me too much time !!
checked my version again V1.0.11.110_10.2.100 no autoupdate available says the router
But when I look on this page : https://www.netgear.com/support/product/r7000.aspx
I see that 18/1/2021 there was a new verions !!! 1.0.11.116
So going to try this ! althouhg the notes do not give me too much hope
- ZsirbacsiAspirant
Hey there,
My Nighthawk R7000 worked really well in the first few months, then I changed ISP and upgraded to 1Gigabit fiber. Since then I have to restart (switch off/on) it nearly every single day. Both wired and wireless connections go off at the same time in random times during the day on all devices. It's really annoying. Might be too much traffic it needs to handle?
It has the firmware V1.0.9.88_10.2.88
Maybe I should downgrade the firmware?
My second option, I am considering to buy a wired router and use the R7000 in Access Point mode to ease its workload.
Any advice welcome, thanks guys.
- ZsirbacsiAspirant
Sorry a few more details:
15-20 devices connected including 4 wired.
Guest network disabled. Parnetal Control disabled. No USB drive attached.
Smart Connect disabled.
2.4 Ghz and 5 Ghz signals are set on channels not conflicting with neighbours.
I'm running out of options. Maybe it's working on its edge.
hmm i'm finished with this router, i am going to implement an option that I found on the internet. I will add a smart plug en reboot it everty night or once a week at a time I sleep ;-)
See : https://www.howtogeek.com/289178/how-to-automatically-reboot-your-router-on-a-schedule-the-easy-way/
it's not how it should work but it's probably a nice (and cheap) bypass !
But my next Router will NOT be a NETGEAR for sure !
- RogetInitiateThe lights on the front/top of the router disappear except for one that is orange on the left and a white one on the right (mounted 10 feet up a wall and poor eyesight. Don’t ask which lights plz) wireless takes a dump and going to 192.168.1.1 let’s me log in but any menu selection gives me that spinning icon. Removing the power for five seconds “fixes” the problem.
I have solved this problem!!! I simply took my Nighthawk router and threw it in the garbage and then connected to an old Linksys router that I found and the problem is solved! Have been up and running on the Linksys router for a few weeks now with no issues.
- onimic70Guide
This is why forums aren't helpful with responses like these. Yet I am running the same Nighthawk routers for 30 office people at my company and my home with no problems. I have thrown out plenty of Linksys routers in my time.
Users should also read, review and check out what others have done as well:
