nzbiship
Aug 18, 2022Aspirant
GS324TP PoE Power Status Off - Can't enable
I have 4 5w Poe devices on ports 1-4. They were working fine with FW 1.0.0.38. I upgraded to 1.0.0.43 and now they are not receiving power. (I did not reset settings to factory default). On setting...
JeraldM
Aug 18, 2022NETGEAR Employee Retired
Welcome to the community!
If setting the switch to factory defaults is not an option, have you tried reverting the FW back to v1.0.0.38 to see if the PoE works again?
JeraldM
NETGEAR Community Team
- nzbishipAug 18, 2022Aspirant
Thanks JeraldM.
I will factory reset first and see - thanks.
