chzhowland
Jun 03, 2022Aspirant
GS324TP switch errors - Discarding the BPDU - Invalid Forward Delay
My GS324TP switch is getting flooded with errors every few seconds as shown in the attached screen capture. I have narrowed this down and the errors only occur when if have the Netgear Orbi RBR50 at...
schumaku
Jun 03, 2022Guru - Experienced User
These Orbi systems make use of STP, require STP properly configured (STP [resp RSTP, it's compatible] and define a prio aka ID of 32768 on switches supporting STP/RSTP/MST. Reads like no STP or RSTP is configured and enabled on the switch, and forward BPDU with STP disabled isn't enabled - so the switch does filter the STP traffic.
chzhowland
Jun 06, 2022Aspirant
thanks for the reply.
I just verified that STP is Enabled in operation mode RSTP. (screen shot attached) As I understand your response, this should be correct to not cause the issue?
From what I have found, this is not a "real" issue but I am having some other issues with the switch as well so I am trying to clean things up, get it right and minimize the logs.
thanks
