TonMachielsen's avatar
Apr 10, 2019
GS510TPP Default password does NOT work anymore after firmware upgrade
I just upgraded the firmware to the latest version and now my password to access the switch doesn't work anymore. Factory reset and configure everything from scratch again?
  • Hi John!
    Yes, i can access the switch now. UNfortunately all my configuration is gone, hence what a factory reset is supposed to do.
    You can close the topic, but i think you should file a bug where after a firmware upgrade the admin password gets reset/scrambled/whatever. Reset no, because i could login with the default password nor could i login with one of my previous passwords. So i guess the only option left is that the password gets corrupted.
    Ton.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi TonMachielsen,
    Welcome to our community! :)
    As per checking the release notes of the latest firmware. It didn't state there that the password will be different from your previous configuration. I suggest, reset the switch to factory default and let's check if you can now log in to the UI.
    JohnCarloV
    NETGEAR Community Team
    • TonMachielsen's avatar
      TonMachielsen
      Hi John!
      Ton.
      • JohnC_V's avatar
        JohnC_V
        TonMachielsen,
        Thanks for the update! I just marked your reply as the solution :)
        JohnCarloV
ProSupport for Business
