keschrich's avatar
keschrich
Follower
Jan 27, 2019
GS516TP IPv6 ACLs with non static /56 from ISP
Background - I'm redoing my home network and need a >=16 port Gigabit switch with PoE. I do have multiple subnets/VLANs and would love for the switch to take over some of the internal routing so I ha...
  • JohnC_V's avatar
    Jan 31, 2019
    Hi keschrich,
    Welcome to our community! :)
    It seems that you wanted to setup ACL for routing traffic between your VLANs. The IPv6 will only be coming from your WAN and not on your LAN, so definitely, you can use any switch that supports POE. Unless, your router also supports IPv6 that broadcasts to LAN. You may use our switch selector in order for you to sort it and find the right switch that meets the needs of your network.
    Here is our switch selector.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
