yagyu
Feb 23, 2021Aspirant
GS716Tv3 Ha SETUP
Hi! I want to set up HA with fortigate firewalls like: switch - fw - switch internet ---> | | | --> LAN sw...
schumaku
Feb 24, 2021Guru - Experienced User
yagyu wrote:I want to set up HA with fortigate firewalls like:
Yes, with Internet connections providing plain IP on the WAN connection (no PPTP, no PPPoE, ...), and permitting you don't expect e.g some L3 features like routing or VRRP, this can be configured with any switch.
General advise: Consult with your firewall vendor for HA/failover/cluster configurtion switch requirements.
JohnC_V no Multi-WAN and so on required for such a HA set-up. HA capable firewalls from Fortigate, Sonicwall, or ZyXEL (this isn't consumer ****) are supporting virtual MAC addresses. FMI:HA Cluster virtual MAC addresses
schumaku
Curious how you intend to connect what akes up the "Internet" at your site - typically a device with just one port - should be connected in a full HA set-up.
