Fabio72's avatar
Fabio72
GS716Tv3 IGMP Snooping breaks IPV6 SLAAC
I'm experiencing the same behaviour of topic https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS724Tv4-Enabling-IGMP-Snooping-on-a-VLAN-Breaks-IPv6-on-that/td-p/995071
As soon as I Enable IGMP Snooping SLAAC and Router Advertizer stop working and I don't have IPV6 connectivity any more.
My pfSense router can still ping6 any external host, so is only a lan VLAN issue.
I tried both firmwares 6.3.1.16 and 6.3.1.11
  • Hi Fabio72,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Have you tried enabling IGMP at the port level and not the VLAN level as suggested on this forum link?
    b. After you have upgraded/downgraded the firmware of the GS716Tv3, did you perform a factory reset then reconfigure it from scratch?
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Fabio72,
    DaneA
      • DaneA's avatar
        DaneA
        Fabio72,
        I'm glad to know that the issue has been solved. :)
        Feel free to post your future concerns here in the community.
        Cheers,
        DaneA
ProSupport for Business
