Fabio72's avatar
Fabio72
GS716Tv3 IGMP Snooping breaks IPV6 SLAAC
I'm experiencing the same behaviour of topic https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS724Tv4-Enabling-IGMP-Snooping-on-a-VLAN-Breaks-IPv6-on-that/td-p/995071 As soon as I Enable ...
  • DaneA's avatar
    Jan 10, 2017
    Hi Fabio72,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Have you tried enabling IGMP at the port level and not the VLAN level as suggested on this forum link?
    b. After you have upgraded/downgraded the firmware of the GS716Tv3, did you perform a factory reset then reconfigure it from scratch?
    DaneA
    NETGEAR Community Team
ProSupport for Business
